Resolved! Off load syslogs
Can xMC off load syslog to another syslog server? If so please show me how. Thank you
Hi all The Analytics browser does not resolve IP to names, although they are available via DNS. Hostname lookup is globally enabled under "Name resolution". DNS on OS level is configured for XMC and Analytics. Any ideas?
Hi I see that XMC is doing logins to all VSPs each 15 minutes. Is there a reason for that or better is there a way to stop that? I disabled all options under "Management Center Collector" that had 15 minutes interval to find the cause, but no succes...
Hi there, I just updated our Extreme Management Center to version 8.2.5.50. After the update completed I started to notice all of our VSPs monitoring go offline. Checking the event logs in Extreme Management Center show all of the VSPs with a task ...
Eg . Our Switch login password as expire on tomorrow. i need previous alret on today.
