Questions and discussions about ExtremeCloud IQ-Site Engine Management Center
Resolved! CLI Login Failed in NAC
Hello,I´ve configured Switch Management Access on X460 to use LDAP via NAC. Everything works fine hands on https://extremeportal.force.com/ExtrArticleDetail?an=000081977But now there is the problem, that our Management Center can´t login to the switc...
Ralf by New Contributor II
  • 1300 Views
  • 3 replies
Integration of Kaspersky security solution with Extreme Networks through the Distributed IPS Connect module
I've made a quick lab on the integration between the Kaspersky security solution and the Extreme Networks solution using the Distributed IPS connect module present on the EMC server. I share with you my lab results and settings. For my lab environm...
