Policy Mangaer "Rule Usage" equivalent in EMC
Hi, is there an equivalent for the legacy Policy Managers feature "Rule Usage" in EMC? If so, does it work with EXOS switches? kind regards,mp2014
Hi, whats the best way to achieve functionality like vlan model and vlan port templates (like in legacy console) in EMC?With the java console app i can define complex VLAN Port templates that can be rolled out to many switch ports abroad many switche...
Alright, I got my hands on some of that sweet, sweet advanced licensing for EMC. So, now I can make floorplans and view some heat maps. I've got a bit of a conundrum, though. I need to plan the AP placments for a new building. I've got a floorpla...
Hello, team,could you please explain me what is wrong:1. I do clean install of NAC 8.2.1.60 under Hyper-V, apply license. It's green in NAC console and in XMC. I add switches required. Everything is OK.2. Then I want to change Diagnostics level to Ve...
Hi All, We're running EMC version 8.1.2.59. We're noticing slowness when using the web gui. Browsing device groups etc makes the devices disappear frequently in the menu and you have to refresh the page to get it back. Seems to be the same regardl...
