XMC: Add Bulk IP addresses to device list
I have 500+ devices to add to XMC that need to be pre-added.Is there a way to do this?
According to the url below the recommended version is 22.06.13.9, but it seems like it has not been updated since November 2022. This is still the recommended version?https://www.extremenetworks.com/support/compatibility-matrices/software-release-rec...
Hello All I have a problem to configure the LLDP configuration ( with the advertise information for VoIP Phone's) in a NAC policy. We are configuring NAC in a existing EXOS network (X670-G2 and x440-G2) As part of the existing EXOS configuration ...
Hi,After upgrading to secure management i didn't configure ISIS IP Source Address, since it is not need any more.The switch is working with the rest of the SPB network.Now I was trying to change the pooling time of the switch in the XIQ-SE and got th...
Hi Hub community,In my XMC server (8.5.4.23), on the initial Network Dashboard, I’ve the “Devices without Reference firmware” widget with yellow color. I know that most of the devices without Reference Firmware are ISP routers that I’m only monitorin...
| User | Count |
| 105 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
