Checkpoint VSX SNMPv3 context
Dan15
Contributor
On Check Point VSX, the snmpv3 context is used to decide which virtual firewall you are actually polling. On other monitoring systems you define the context in the snmp credentials. So four each virtual firewall you use a different credential. I cannot find this option in XMC. Via legacy console there's an option when adding a device to choose the snmp context, but it warns you about unsupport for Oneview. Does anybody know how to achieve that?
Regards
Dany
0 REPLIES 0
