Extreme Management Center - Tasks - Scheduled Tasks
Chris_Skelton
Hi there, I was hoping to get some information regarding scheduled tasks in Extreme Management Center. I'd like to start small and schedule a basic script to run on a device. When I attempt to create a scheduled task i select "Type - Scripting Task" from the pull-down menu. When I select "Script Task Name" the pull-down menu is empty. This is where I'm stuck as I don't know why there are no scripts to select. The "Tasks - Scripts" section is full of different scripts to choose. Clearly I'm missing something but I've read the help files and I haven't found much that goes into detail regarding the building of a scheduled script task.
If anyone has some experience with this I would be grateful for your insight.
Thanks for your help.
Chris
1 ACCEPTED SOLUTION
John_Moore
Hi Chris,
The Script Task Name drop-down list populates with scripts you have saved as a Saved Task. To save a script as a Saved Task, select it on the Scripts tab and click Run. The Run Script dialog box appears. On the Run-Time Settings tab, select Run Now and Save as a Task or Save as a Task (depending on whether you want to run it now AND save it as a Saved Task, or just save it as a Saved Task to run later). Continue through all of the tabs in the dialog box and click the Run button. The script is saved as a Saved Task, which allows it to be selected as a Scheduled Task.
For more info, check out the following link:
https://emc.extremenetworks.com/content/oneview/docs/tasks/docs/ov_ht_schedule.htm
Thanks!
John
2 REPLIES 2
Chris_Skelton
Hi John, thank you very much for your prompt and informative response. Part of my issue was that I was creating CLI scripts which doesn't show the additional options you mentioned. I guess that method isn't supported for scheduling.
Thanks again, very helpful.
Chris
John_Moore
Hi Chris,
Thanks!
John
