increasing wifi speed using AP410c
svettori
HI, we are new to Extreme Network product. we have just installed new AP410c APs in our new office and we have noticed that client connect to speed of 286/286 (Mbps)
is there a way to increade it?
additional info:
-protocol : Wi-Fi 6 (802.11ax)
-Wifi Frequency: 5 GHz
-latest windows drivers
thanks for your help
Stefano
7 REPLIES 7
ckelly
Stefano, the connection speed between a client and the AP will vary, based upon connection conditions. You can configure the AP to have a certain maximum possible connection speed but that does guarantee that this speed will be used.
Christoph_S
Hello @svettori,
This article will give you an idea of what speeds to expect although 4x4:4 spacial stream data is not included.
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000116378
Recommendations:
1 - Create a new radio profile so that you may make changes to the parameters therein
2 - Enable DFS channels
3 - Change channel width to 40Mhz and if you don't have too many APs you can even test with 80MHz channel width
4 - Enable OFDMA in both directions. In default profile this is not enabled.
Test to see if speeds increase.
BR,
Chris
Christoph S.
James_A
Valued Contributor
Are you running a 40MHz channel? Based on https://mcsindex.com/ you're probably only using 20MHz, if the client is 2SS
