when restart extreme controller c5210 flash device unmount
Mikaeil_Beigpou
New Contributor II
when restart extreme controller c5210 flash device unmount version 10.31.03.0012
8 REPLIES 8
Mikaeil_Beigpou
New Contributor II
flash mount at any controller and i see filese when restart controller flash unmount at one of the controller and other controller donot have any problem.
Ronald_Dvorak
Honored Contributor
OK so you have 2 controller with v10.31.03 and 1 has a problem with the flash card.
What happens if you put the flash that doesn't work in the other controller - does it work or not ?
That would tell us whether it's a controller or flash issue.
Mikaeil_Beigpou
New Contributor II
I have 2 controller and flash donot have any problem with other controller,
Ronald_Dvorak
Honored Contributor
- why are you unable to open a GTAC ticket
- what exact model/maker is the flash, have you tried a other model/maker, does it happen with more then one controller
