controller assisted mobility will help ?
Aviv_Kedem
Contributor
We have in some warehouse, is divided with 2 ip segments.We have here only unmanaged switches, with 20 pices of AP6532 and 20-25 wireless clients.
We need to make wireless clients to roam between 2 ip segments.
If we configure VC with controller assisted mobility + layer3 adoption, it will make the roaming work?
Or just only way is buy NX/VX for tunneling WLAN traffic to controller ?
Thanks
11 REPLIES 11
Aviv_Kedem
Contributor
Just got the official approving that VX9000 does supports tunneling and there is support for the configuration.
But it is important be considered about amount of traffic will be forwarded in case of tunneling wireless clients data.
Thanks to all
Thank you
Hi Aviv,
I am glad this might work for you within your environment.
But be aware as stated prior that deployment would not supported by the support desk if you run into issues pertaining to those tunneled vlans.
Forwarding/Tunneling vlans on platforms that do not have a dedicated dataplane is not recommended.
Timo1
New Contributor II
Get a RFS4010, is the cheapest solution.
If you use just a VC you can configure a L2TPv3 tunnel for L3 mobility. But you need an endpoint for this.
Maybe you have a firewall that can run as L2TPv3 endpoint.
