Adding a multicast stream using L3
  • Problem
  • Updated 3 weeks ago
  • Not a Problem
I have added a new multicast stream , I have the server and on layer 2 I can see the correct streams ,, and on the edge device,  I have MOP configured on the vlan and on the interlink vlan on the routing points  , I have a rp configured and a cbsp both configured on our core .
There is a profile configured
The source address is
From the edge I get:   4  0  255  0 0  0   0  0     0      0
So we can see a number of streams from the address
From the edge switch
 Slot-1 K2-SVR-SW-DS-1.1 # sh pim rp-set
Group           Mask            C-RP            Origin    Priority  Timeout Bootstrap 75        119
Slot-1 K2-SVR-SW-DS-1.2 #
Which is understand is correct.
When looking at the core :
sh  igmp snooping vLAN xxx-CORE-RT_xxx-SVR-DS_VR-Default
Which is the point to point link between my core and edge switch
I can see
LAN xxx-CORE-RT_xxx-SVR-DS_VR-Default (xxx) Snooping=Enabled
    Group           Sender          Age 10 1   0  0  0  0 ( I understand this is a SAP/SNMP comms )
    6 Incoming multicast streams
    Port   Host            Subscribed        Age    Group-Limit
    1 All Groups        3      0
So my question is why cannot I see the stream on the core .
What is address from source ? (SAP/sNMP )
I can see the above but not the address :( is the address that I am looking for the stream from
 ( Stream address )
So what am I missing ?
Photo of Rod Robertson
Rod Robertson
  • 2,272 Points 2k badge 2x thumb
Posted 1 month ago
Photo of Bastian Sprotte
Bastian Sprotte, Employee
  • 1,590 Points 1k badge 2x thumb
Hello Rob,
please check the TTL from the stream, you just trace the packets with Wireshark,
this will allow to see is the TTL will allow to route the packet.
Rod Robertson
Hi Sorry for the delay , I go back out to site later this week so I can check.
Carrying on from this .
I know PIM uses the configured routing protocol , in this case OSPF.
The vlan that I have this server on is part of OSPF area though it is configure as Passive would this have an effect on the multicast .
Sort of funny question as the SAP Multicast is getting through.
Looking forward to any suggestions
Photo of EtherMAN
EtherMAN, Embassador
  • 6,236 Points 5k badge 2x thumb
Couple of comments ... First when i see the and 255 I am pretty certain then that is a windows box of some kind with Universal Plug and Play enabled.  It typically  uses port 1900 and can be very chatty.
As far as the stream mcast address not showing up in the core not sure about that but as a rule it will only be learned when there is a valid client asking for the stream and the stream being forwarding across the core link and active.
Rod Robertson
Well Its been a few weeks now .
Returned to site to do some more investigation.
It would appear that the multicast was working for the rest of the network , just not the distribution pair of switches I was connected to , and testing on ..
So basically that's it , thanslk for all your help , I expect in my environment it will be another 5 years till I look at this again
