alternate stacking with x460 using summitstack-v80 card
  • Question
  • Updated 4 years ago
  • Answered
Hi - can anyone assist- I have 3 x460 switches that I am stacking, each switch uses the summitstack-v80 card with fiber optic cables. I am pretty sure its configured correctly as follows-
1- all 3 switches have identical images on same partition
2- license level on all 3 is edge
3- before cabling them up I ran (configure stacking-support stack-port all selection alternate) then roboot all switches individually.
4- at this stage I have cabled them in a ring topology 1-2 1-2 and 1-2 sequence
5-once the switches come up I ran the sh stacking to see if all switches show up but only one shows up not the other two (here all 3 should show up as disabled
6 i check the stacking protocol and its standard on all switches
7- i run the configure easy-setup command and reboot, once all switches  come up they do not form a stack instead they become seperate switches
also there is no link light on the summitstack- v80 modules at all
can you assist please.
Photo of SajK
SajK
  • 100 Points 100 badge 2x thumb
Posted 4 years ago
Photo of aTomo
aTomo
  • 140 Points 100 badge 2x thumb
Official Response
You should not configure stack-port all selection alternate. The summitstack-v80 is "native"
The alternate ports on the x460 is the module with two 10 gb ports if you have that installed.
