AP-7622 configuration interface
  • 2
  • Problem
  • Updated 4 months ago
  • Not a Problem
İ have ap-7622. İ can't connect to configuration interface with default ip written on the device. Amber led is steady. Other leds none. Device is connect to modem via GE1/POE port.
Please help me. Thanks.
Photo of Erkan Guven
Erkan Guven
  • 80 Points 75 badge 2x thumb
Posted 6 months ago
  • 2
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,186 Points 1k badge 2x thumb
Have you tried CLI and GUI?
If so then you may need to reset the AP to factory default using a console cable.
Photo of gluo
gluo
  • 708 Points 500 badge 2x thumb
Is it a new device? Could try flashing the full firmware, maybe it has been shipped with Lean firmware which has no UI.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Why-I-am-unable-to-log-into-newly-bought-AP75...
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,710 Points 20k badge 2x thumb
Erkan,
Are you all set at this point or are you still having issues?
