Brocade VDX6740 constant reboot
  • Problem
  • Updated 4 months ago
  • Solved
Switch constantly reboots, here is a printout of the boot process:
Unrecognized Cobra version '', defaulting to rev B
 vsmgr : disk xfer failed for IO: READ size:69632 ret size 0
HV>
 Current Mode of Op:interrupt Vs Thread State:0x0 blockPos:0x0
 Current Active cookie Gos0:0xe41 Gos1:0x0
 Current Queued max cookie Gos0:0xe42 Gos1:0x0
 Guest sem info data 0x0 waitlist 0x0
 Guest mutex info data 0x0 waitlist 0x0
 Usb host controller status 0x40080
 Number of Interrupts 0x2ae1 Num_of_blocks 0x2ae6
 VS queue head pos :0x9080 tail pos:0x9080
 HV USB timer: no of times exp 0xf No of times start 0x2af0  No of times  stop 0x2af0
 cur_io_info disk 0x0: cookie 0xe42
 Num Critical errors=5 Real errors=0
 GOS0 flush_io_sem info data 0x0 waitlist 0x0
 GOS1 flush_io_sem info data 0x0 waitlist 0x0
 usb_io_err_counters excluding the current io :
 num_read_errs 0x0 num_write_errs 0x0
 num_rd_usb_resets 0x0 num_wr_usb_resets 0x0 num_usb_stall 0x0 num_usb_st_buff_err 0x0
 num_usb_babble_err 0x0 num_usb_crc_err 0x0 num_usb_stalls 0x0
 num_non_critical 0x0 num_ehci_timeouts 0x0
 usb_io_err_counters encounter in the current io :
 num_read_errs 0x5 num_write_errs 0x0
 num_non_critical 0x5 num_ehci_timeouts 0x5
[2]
Hypervisor Reset Flush:
BootROM version: 1.0.60
Copyright (C) 2011 Brocade Communication.
CPU0:  P3041, Version: 2.0, (0x82110320)
Core:  E500MC, Version: 3.2, (0x80230032)
Clock Configuration:
       CPU0:1500 MHz, CPU1:1500 MHz, CPU2:1500 MHz, CPU3:1500 MHz,
       CCB:750  MHz,
       DDR:500  MHz (1000 MT/s data rate) (Asynchronous), LBC:46.875 MHz
       FMAN1: 375 MHz
       PME:   375 MHz
L1:    D-cache 32 kB enabled
       I-cache 32 kB enabled
Model ID: 131
Board: P3041 CASTOR, 36-bit Addressing
reset reason was 0x00000002: CPU request
I2C:   ready
DRAM:  Initializing....
Enabled DHC_EN
FSL_ERRATUM_DDR_A003 workaround applied
DIMM 0 [0xfe008174=0x8675a607] [0xfe008f38=0x11110e0c] [0xfe008f3c=0x0a0c0d0f] [0xfe008f40=0x0d004004]
6 GiB left unmapped
    DDR: 8 GiB (DDR3, 64-bit, CL=7, ECC on)
testdram value not set, dram test not run
Now running in RAM - U-Boot at: 7ff20000
FLASH: 4 MiB
L2:    128 KB enabled
Corenet Platform Cache: 1024 KB enabled
SERDES: bank 2 disabled
PCI: gd->brcd_flags = 0, PCI init
    PCIE1 connected to Slot 1 as Root Complex (base addr fe200000)
               Scanning PCI bus 01
    PCIE0 on bus 00 - 01
MMK configuring pit regs
In:    serial
Out:   serial
Err:   serial
    SRIO1: disabled
    SRIO2: disabled
NVRAM/RTC oscillator already turned on in a previous boot
Net:   Fman: Uploading microcode version 101.6.0.
FM1@DTSEC4, FM1@DTSEC5
usb reset 0
(Re)start USB 0...
USB:   Register 10011 NbrPorts 1
USB EHCI 1.00
scanning bus for devices... Manufacturer u-boot
Product      EHCI Host Controller
SerialNumber
Manufacturer Generic
Product      Flash Card Reader
SerialNumber 000000225001
2 USB Device(s) found
       scanning bus for storage devices... 1 Storage Device(s) found
setting prt to 2
Hit ESC to stop autoboot:  0
Loading Environment 1 from NVRAM...
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 1
Loading Environment 0 from NVRAM...
(Re)start USB 0...
USB EHCI 1.00
SerialNumber
setting prt to 2
Loading file "/boot/fastloading.mdt" from usb device 0:2 (usbda2)
158 bytes read
Image: [uImage]
 Image: [hv.uImage]
 Image: [silkworm.dtb]
 Image: [silkworm_hct.dtb]
 WARNING: adjusting available memory to 30000000
## Booting kernel from Legacy Image at 02000000 ...
   Image Name:
   Image Type:   PowerPC Linux Kernel Image (uncompressed)
   Data Size:    473624 Bytes = 462.5 KiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 04000000
   Booting using the fdt blob at 0x4000000
   Loading Kernel Image ... OK
OK
   Loading Device Tree to 00ff7000, end 00fff22b ... OK
Freescale Hypervisor 0.8-004
Hypervisor command line: config-addr=0x3000000 p1-linux="root=/dev/sda2  rootfstype=ext4 quiet" p2-linux="root=/dev/sda1 rootfstype=ext4 quiet ip=bootp"
[0] malloc_init: using 31 MiB at 0x7e0e2b70 - 0x7fffffff
Brocade PB device tree:brocade,SILKWORM_PB
Got liodn 125
[0] assign_callback: device serial0 in serial0 not found
[0] assign_callback: device /hvcpld in fpga not found
USB:
Static Qhead=0x4d6080 Qhead list=0x4d6100 Qtd base=0x4d6180
Static Qhead Align=[0] Qhead list Align=[0] Qtd base=[0]
hv scanning bus for usb devices... 2 USB Device(s) found
[0] watchdog enabled with period 38
 hv  scanning bus for storage devices... 1  HV Storage Device(s) found
Init hypervisor timer init_timer:8
[2] watchdog enabled with period 38
[3] watchdog enabled with period 38
[1] watchdog enabled with period 38
[2] Virtual Storage thread=7e260008
[0] get_rpn: mem-range has discontiguity at guest address 0x68000000.
HV>
 part_start 2  2
HV>
dev_name vs_attach_guest   /vsmgr/vd@usb0/vda01 part_start 2 no_of_parts 2
 [vs_attach_guest]vdisk->start 0x7737ff vdisk->size 0x773001
HV>
Bootargs set for cpu = 2 guest p2-linux bootagrs = root=/dev/sda1 rootfstype=ext4 quiet ip=bootp
HV>
 part2 STANDBY
HV>
 part_start 0  2
HV>
dev_name vs_attach_guest   /vsmgr/vd@usb0/vda00 part_start 0 no_of_parts 2
HV>
 [vs_attach_guest]vdisk->start 0x0 vdisk->size 0x773800
HV>
Bootargs set for cpu = 0 guest p1-linux bootagrs = root=/dev/sda2  rootfstype=ext4 quiet
HV>
 part1 ACTIVE
patch_pcie_msi_guest_node:set p2-linux msi0
patch_pcie_msi_guest_node: set msi-address-64 f0000740
[0] Clearing standby console log
[0] loading binary image from 0x79fff000 to 0x3000000
[0] Loading uImage from 0x78000000 to 0
[2] loading binary image from 0x79fff000 to 0x3000000
[2] Loading uImage from 0x78000000 to 0
[2] branching to guest p2-linux, 2 cpus
[0] branching to guest p1-linux, 2 cpus
HV> this is quiet!
 end of DRAM 4294967296 memstart_addr0 total_lowmem 4294967296
[silkworm_setup_pci_shared_memory]config_done  0 scandone 0 pcilcok 0x0
SLUB: dfree enabled
PRIMING SLUB: main caches
SLUB: export __kmalloc at 0x40108204 changed to 0x401085c4
SLUB: export vmalloc at 0x400f6404 changed to 0x400f61b8
SLUB: export vfree at 0x400f5578 changed to 0x400f54a8
network namespace NR (VRF) started
 PCI_PROBE_DEVTREE
 PCI_PROBE_DEVTREE
mmod_sysctl_inited: 1
***** pcie_portdrv_init: active completed
cpu1/1: failover_register() - registering notifiers...
 Fman microcode       51       45       46
 FMAN microcode UC size 0x1b64
default MII is 0xc10b0000 for tsec0
Uboot wdt counter value: 0
VSD Created with major number vsd_probe = 254
 disk->start 0  cmd->start 0 nstart 0 disk name /vsmgr/vd@usb0/vda00
HV>
create_new_partition_table part_no 0 no_of_parts 2
INIT: version 2.78 booting
Firmware Integrity Check is default off
Bypassing firmware validation.
mount: sysfs already mounted or /sys busy
mount: according to mtab, none is already mounted on /sys
mknod: /dev/fsl-hv: File exists
Hostname is VDX-Switch-02
INIT: Entering runlevel: 3
        FIPS-mode test application
1. Non-Approved cryptographic operation test...
        a. Excluded algorithm (MD5)...successful
        b. Included algorithm (D-H)...successful
2. Automatic power-up self test...
        2.a. FIPS RNG selftest...successful
3. AES-128,192,256 CBC  encryption/decryption...successful
4. RSA key generation and encryption/decryption...successful
4.1. RSA 2048 with 'SHA256' testing...successful
5. TDES-CBC encryption/decryption...successful
6a. SHA-1 hash...successful
6b. SHA-256 hash...successful
6c. SHA-384 hash...successful
6d. SHA-512 hash...successful
6e. HMAC-SHA-1 hash...successful
6f. HMAC-SHA-224 hash...successful
6g. HMAC-SHA-256 hash...successful
6h. HMAC-SHA-384 hash...successful
6i. HMAC-SHA-512 hash...successful
7. Non-Approved cryptographic operation test...
        a. Excluded algorithm (MD5)...Not executed
        b. Included algorithm (D-H)...successful as expected
8. Zero-ization...Successful
9. TLS KDF 1.0...successful
9a. TLS KDF 1.2...successful
10.ECDSA ...successful
11.ECDH ...successful
11. SSH KDF...successful
All tests completed with 0 errors
(none)
Waiting to starting configuration management service
Starting configuration management service
Found 2(threshold 5) abnormal reboots within 5000 seconds window(threshold)
KernelSpace rastrace_register
 DCM MODE:0x0
SWBD module launch ... Thu Jan 25 18:55:46 GMT 2018
CPLD INIT DONE
SEEPROM Read Done!
Unrecognized Cobra version '', defaulting to rev B  <======THIS IS THE LAST LINE, THEN
STARTS AGAIN FROM THE TOP!!
Photo of Adam Aronson
Adam Aronson
  • 100 Points 100 badge 2x thumb
Posted 4 months ago
Adam Aronson
Changed the active partition to sda1 from sda2, rebooted and found error "SCSI_REQ_SENSE failed cmd 0x03 returned 0x70 0x06 0x28 0x00" which indicates a hardware issue.
Photo of Drew C.
Drew C., Community Manager
  • 36,926 Points 20k badge 2x thumb
Thanks for coming back with an update on this!
