Can not add Extreme Wireless Controller to Netsight
Yakup_Erdol
New Contributor III
Hi all,
We have installed Netsight with version 7.1.3.25 and EWC with version 10.21.04.0005. Netsight can discover switches and NAC appliances using snmpv3 credentials. But we can not add wireless controller using same snmpv3 credentials.
Netsight is not at the same Vlan with Controller or other devices, but they are all reachable. EWC can ping Netsight from data and management IPs.
Thanks.
10 REPLIES 10
Yakup_Erdol
New Contributor III
Thanks Karthik,
After removing the "Context String" Netsight is able to discover the EWC.
Thanks all.
Emre_Kurtman
Hi Yakup, Regarding the java problem, this is probably because of your PCs language settings. Change the language to English, clear the Java cache then try again please.
Emre Kurtman Technical Marketing Engineer / Extreme Networks
Umut_Aydin
Or you use the same snmp context if you add the EWC to Netsight..
Karthik_Mohando
Hi Yakup,
Would you be able to check the same after removing the "Context String" from the SNMPV3 setting in EWC?
**edit**
