Do any Extreme AP's offer anything similar to Ciscos Mobility Express?
  • Question
  • Updated 4 days ago
  • Answered
Client upgrading AP's and looking to install Extreme APs but they won't be buying a Wireless Controller. Doing some research and trying to find if Extreme AP's have any similar features to Ciscos Mobility Express in which a single AP can act as a controller?
Photo of scott parry
scott parry
  • 70 Points
Posted 7 months ago
Photo of Mathew Sebastian
Mathew Sebastian, Employee
  • 94 Points 75 badge 2x thumb
Yes, Extreme WiNG APs can act as controller. User may configure Virtual Controller config option
Photo of Timo
Timo
  • 3,210 Points 3k badge 2x thumb
As Mathew write, yes. For WiNG APs, but depend on model and firmware you may only manage APs of the same type.
Photo of Andy Holden
Andy Holden, Employee
  • 1,492 Points 1k badge 2x thumb
To echo the previous comments, Wing APs can act as a controllers for managing adopted APs. We can also be configured to allow for a backup in the event the Virtual Controller goes off line. One additional feature is that the Virtual Controller is used only for management, allowing the AP to operate independently of the controller
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,186 Points 1k badge 2x thumb
Hi Scott,
As per my colleagues' responses above - WiNG's 'AP Virtual Controller' mode sounds like just the ticket for your application.  There are some variations depending on AP type but with our mid and high-tier APs we can support up to 64 APs in VC mode.  The VC can be manually set with a primary and secondary, or just left to be auto-elected to give almost infinite redundancy.  Also with some mid-tier and all top-tier APs we have introduced 'heterogeneous AP support' whereby high-spec APs can also manage lower-specification APs.  E.g. The 8432 and 8533 APs can manage all other models of AP.  The 7632 AP can manage or be managed by 7662 APs. Please see the attached infographic.  Also there's no licensing requirements for AP virtual controller mode! :-) One word of note is that all the APs need to be connected on the same L2 LAN segment.  They can't be routed or on separate VLANs for management (user traffic can use multiple VLANs of course).
Hope that helps,
Darrel.
(Edited)
Photo of Ismael
Ismael
  • 418 Points 250 badge 2x thumb
Hi Scott, im testing this option to configure an AP8432 as VC to manage two AP7532 but i have some issues. Could you please share a document or link whit the instructions to use this option?
i have already upgrade all the APs to 5.9.1.3.
Thank you in advance.
Photo of dmelo63
dmelo63
  • 92 Points 75 badge 2x thumb
Just looking to confirm how many AP's a mid-tier 7662 acting as the VC can support?  And are there any newer presentations on VC? I have one from December 2017 5.9.1 release
(Edited)
Photo of Tomasz
Tomasz
  • 1,104 Points 1k badge 2x thumb
7662 (outdoor) can adopt up to 64 APs: 7612, 7632, 7662.
HTH,
Tomasz
Photo of Aviv Kedem
Aviv Kedem
  • 1,714 Points 1k badge 2x thumb
Hello guys,
How can I manually set up (with CLI) the VC  as a primary or secondary ?
Thanks
Photo of Aviv Kedem
Aviv Kedem
Anyone? Please...
Photo of Aviv Kedem
Aviv Kedem
I will open a new topic
