EAPS - MLAG and Cisco port-channel
  • Question
  • Updated 9 months ago
  • Answered
Hello all,
recently we have a problem with a trunk interfaces and tagged interfaces.
so i decide to take a new option of the design, but a co worked told me that is not posible this kind of design because he said to me that you cannot have a MLAG and EAPS in the same device, so before making anything in production or lab i want to know your experience if anyone of you made this kind of topology.
Photo of Sebastian Rojas
Sebastian Rojas
  • 346 Points 250 badge 2x thumb
Posted 9 months ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
It is not recommended to have a l2 redundancy protocol enabled on a MLAG port. In this scenario you can you use EAPS as long as the EAPS master is not one of the MLAG peers. This way the ISC will never be blocked.
Photo of Bin
Bin, Employee
  • 5,372 Points 5k badge 2x thumb
Hi Sebastian,
Please our "MLAG Limitations and Requirements"
https://documentation.extremenetworks.com/exos_22.2/exos_21_1/slots_and_ports/r_limitations-and-requ...
  • MLAG ports cannot be configured to be EAPS ring ports.
  • Configuration of the ISC port as an EAPS blocked port is disallowed
Sebastian Rojas
Helo Bin, i read the doc, so i have to make another link between the devices to run the ISC connection without adding to the eaps ring and only tagging the l3 vlan for control traffic.
Photo of faste
faste
  • 190 Points 100 badge 2x thumb
I’ve been running this setup for several years now. No troubles.
Sebastian Rojas
Hello Faste, i'm going to make a lab the next wednesday, thanks for your opinion!
Photo of faste
faste
Enable sharing port 25 grouping 25-29 lacp algoritm address-based L3_L4 on both switches
Enable mlag port 25 peer xxx id 1
(Port 25 is the port(group) that is connected to the cisco switch)
ISC link duplicated as the sketch shows here and it's also the eaps-link between the two switches.
