ELRP uplink port question
  • Question
  • Updated 3 years ago
  • Answered
We are running ELRP on all our ports. including the 10gig ports; that we use for our backbone. on stacks with the 460 48 port switches. We had a loop created when two switches were connected via 1gig ports ( ex stack 1 port 12 to stack 2 port 8). As expected elrp shut down those two ports and the backbone ports(ex 1:53 ) on both switches. We were considering taking the elrp off the backbone ports so it we wouldn't lose connection to the switch when this type of loop happens.
my question is with elrp no active on the backbone ports. will elrp still recognize the loop( since it is not monitoring the backbone) and if it does see the loop. It will still shutdown the 1 gig port only.
Thanks,
Photo of christopher madison
christopher madison
  • 360 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
In your design, it would be best practice to not have ELRP on the uplinks and just on the edge ports.  There is a new feature in 16.1 where you can define the port that will be disabled, either the ingress or egress port.  This would allow you to make sure uplink does not get disabled.  My suggestion is to not have the uplinks participate. Here is the new command line options....
configure elrp-client periodic <vlan> ports <{portlist} |
all> {interval <seconds>} [log |log-and-trap | trap]
{disable-port {egress | ingress} {duration {<seconds>} |
permanent}}
Bill
Photo of Kawawa
Kawawa, GTAC
  • 3,292 Points 3k badge 2x thumb
If you disable ELRP, it won't see or do anything.  But you can change what action it takes when it identifies a loop.  With the commands Bill has highlighted above, you can simply set it to Log/Log & Trap/ Trap, allowing you to be notified.  Most production environments I have worked with simply have it set to log/trap the loops and the network team then remotes takes the best corrective action based on the circumstances
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,594 Points 10k badge 2x thumb
You can keep the same configuration and just exclude the uplink ports from being disabled if there is a loop. This is explained in the article below:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-ELRP-to-disable-ports
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 13,346 Points 10k badge 2x thumb
Hi Christopher,
In my understanding this statement:
"As expected elrp shut down those two ports and the backbone ports(ex 1:53 ) on both switches."
Is not expected.
It should shut down one port. If you don't have the uplinks in the exclude list, they might be the one shut down. Actually, by default, the port being shut down is the receiving port where the ELRP PDU is received. This can be change by configuration starting with 16.1, as Bill stated.
