EXOS Identity Management - MIBs
Stephen_Elliot1
Contributor
Does anyone use MIBs to extract Identity Management data from EXOS switches?
I've found the OID 'ExtremeLocationInetAddrEntry' which shows port, mac address & IP address of the 'identity-management entries'. (MIB 16.1.4.2)
But crazily, there's not one which shows the logged in username.
Any ideas?
Thanks.
3 REPLIES 3
Stephen_Elliot1
Contributor
OK, thanks for your reply Derek.
Absolutely. I just wish I had a better (i.e. available today) answer for you.
Derek_Bird
Stephen:
Unfortunately, the OID you want doesn't currently exist, and I don't have an SNMP workaround for you at this moment.
I'd suggest you open a Feature Request, which you can do online at the Support Portal.
