external antennas for wireless bridge
  • Question
  • Updated 3 months ago
  • Answered
Hi
I need to make a wireless bridge between two buildings (150 meters), no cables.
I have seen that with two simple AP7522 I could do it (I understand that using meshconnex configuration).
Which antenna should I use for outdoor in this case?
Thanks in advance.
Regards.
Photo of Jose_LV
Jose_LV
  • 1,274 Points 1k badge 2x thumb
Posted 3 months ago
Photo of Michael (Misha) Elin
Michael (Misha) Elin, SE
  • 506 Points 500 badge 2x thumb
Hello,
  Here is some considerations:
1. MIMO is not working outdoor so you could expect 150Mbps rate maximum
2. Check "show wireless regulatory device-type ap7522 <your_country_code>" for DFS and maximum allowed power including antenna gain.
I could recommend two patch/narrow pattern antennas and 1xALL antenna mode. I.e. AP will use always one (primary) antenna to send signal and both antennas for listening. Use this for link budget calculations.
Misha
