Extreme Summit Switches Upgrade Patch
  • Question
  • Updated 2 years ago
  • Answered
Hi All,
I am going to upgrade the Extreme Summit Switches x460 from 12.5.4.5 to 16.1.3.6. Is that any required path need to achieve first or can directly upgrade from 12.5 to 16.1 within one step?
Thanks for your help.
Best regards,
Chia Hong
Photo of Revil Hong
Revil Hong
  • 90 Points 75 badge 2x thumb
  • thankful
Posted 2 years ago
Photo of Stephen Williams
Stephen Williams, Employee
  • 9,040 Points 5k badge 2x thumb
You shouldn't have any problem going from 12.5 to 16.1.
Photo of Edward Tsui
Edward Tsui, Employee
  • 602 Points 500 badge 2x thumb
Hi Revil,
You may find the upgrade procedure here. For x460 upgrade, download the image to alternate partition and then reboot (By default, the boot partition will be changed to alternate partition after image download). If you have modules like SSH module, you need to install it prior to reboot.
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-Obtain-and-Upgrade-EXOS/?q=upgrade&...
