Extreme Summit X670V STP disabled by default, it still will send BPDU package?
  • Question
  • Updated 2 years ago
  • Answered
I just wanted to know if it still will send BPDU package when STP not enabled on Extreme Summit switch. From my understanding, it should not send BPDU message when STP not enabled. The background - As in our Production Env, we enabled BPDU guard on cisco Nexus 7K one Trunk port connected to a Summit X670V switch to root guard. However, a mistaken operation on the Summit switch by putting all port to a VLAN cause the Cisco switch received a large of BPDU package then put the port on the err-disabled status.
Photo of Wallance
Wallance
  • 260 Points 250 badge 2x thumb
Posted 3 years ago
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,304 Points 10k badge 2x thumb
Official Response
Hi Wallance,
The X670V will not send BPDUs when STP is disabled. However, it will forward any BPDUs that it receives, as the switch sees them as standard multicast frames.
-Brandon
Official Response
You can block the BPDUs via an ACL on the port, if you want the switch to not forward them. See the following GTAC Knowledge article for details:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-block-BPDU-packets-on-a-port-via-AC...
-Brandon
(Edited)
