Extreme Wing with Extreme Management
  • Question
  • Updated 9 months ago
  • Answered
  • (Edited)
Hi Community
We have a client that have deployed just over 1000 Wing AP's when it was still a Zebra product.
The client is now looking at a Management system to manage the whole solution.
I am looking at using the Extreme Management (Netsight) instead of NSight.
How much of the Wing management can be currently done with Extreme Management currently?
Or should I still look at Nsight right now?
We do not want to supply Nsight if the product have no roadmap.
Thx
Photo of Andre Brits Kannemeyer
  • 5,010 Points 5k badge 2x thumb
Posted 9 months ago
Photo of Alona
Alona, Employee
  • 1,620 Points 1k badge 2x thumb
Which APs? Do you have a controller? If yes, which one? What are your requirements from management system?
The client have deployed numerous RFS2000's, RFS4000's and 75xx AP's
Photo of Darrel Rhodes
Darrel Rhodes, Employee
  • 1,070 Points 1k badge 2x thumb
Andre, I would consider deploying a VX/NX9k to manage the existing controllers and run the NSight server.
The client just deployed a NX9000 in AWS and we will be migrating all management to this central controller ;)
Perfect! :-)
Hi Andre,
Right now NSight is the only option for a WiNG customer to have full monitoring and analytics on the wireless network.
EMC will only provide basic SNMP monitoring.
However I understand the roadmap is for NSight to be rolled into EMC for customers with mixed platform networks.
I would recommend you have a look at a demo of NSight as it is a fantastic application that shows the customer an incredible amount of data, statistics, history and insight in to the usage and behaviour of the WiNG network.
Thanks,
Darrel.
  • 4,980 Points 4k badge 2x thumb
Ok great so for now stick with Nsight
Definitely! :-)
Photo of Shay Weir
Shay Weir
  • 1,648 Points 1k badge 2x thumb
NSight currently is a monitoring tool.  No management built in....yet.  road map does show it being added and also some features from WiNG being to Extreme NetSight.  There are still ways to roll up the management with WiNG to a central management controller, but only if you have nx7500 or lower controllers.  You can roll up under a nx9600.  Have to go up one size to combine multiple controllers into one console.  We are holding out for the NSight features coming down within the future releases.  WiNG 5.9.1 ......
