I'm seeing several "failed WPA2-AES handshake on wlan ...." in my logs for multiple devices on AP7522/AP6521 adopted to RFS6000 running 5.8.3.1 and the WLAN is running TKIP-CCMP. I can see the device failing the handshake every 15-30 seconds on several different APs.
I am in the process of changing this infrastructure but wanted to know if there's something I can do in the meantime.
What are the main reasons for this?
Thanks in advance
Bruno
Thanks in advance
Bruno
310 Points
Posted 2 weeks ago
Ondrej Lepa, Employee
4,614 Points
Hi Bruno,
try to avoid use of TKIP.
Some devices won't respond to EAPoL calls while support for TKIP is maintained.
Regards,
Ondrej
Regards,
Ondrej
(Edited)
Andrew Blomley, Employee
282 Points
I would also look at the RF environment, are you using SMART-RF, is so can you send the smart-rf configuration, please.
it will also be worth seeing what the interference is like.
show smart-rf interfering-ap on <rf-domain>
what are you changing the infrastructure too?
310 Points
Hi Andrew,
All we have in the smart-rf policy is:
channel-width 5GHz 20MHz
no neighbor-recovery
no coverage-hole-recovery
The interferers are about 4 of our own APs that are part of a different RF-Domain (which I assume is the cause)
INTERFERER VENDOR RADIO RADIO-MAC CHNL RSSI
84-24-8D-91-0B-00 Zebra Tech AP52:R1 84-24-8D-91-8E-80 1 -64
74-67-F7-78-3D-10 Zebra Tech ap6521-43C2F0:R1 FC-0A-81-D3-52-A0 1 -65
84-24-8D-91-0B-00 Zebra Tech ap6521-43C7F8:R1 FC-0A-81-D3-51-B0 11 -68
84-24-8D-91-0B-00 Zebra Tech ap6521-43C7F8:R1 FC-0A-81-D3-51-B0 1 -68
84-24-8D-91-0B-00 Zebra Tech AP22:R1 84-24-8D-91-95-10 1 -68
74-67-F7-78-3D-10 Zebra Tech ap6521-43C85A:R1 FC-0A-81-D3-46-C0 1 -68
74-67-F7-78-3E-10 Zebra Tech ap6521-43C85A:R1 FC-0A-81-D3-46-C0 1 -69
84-24-8D-91-0B-00 Zebra Tech AP26:R1 84-24-8D-8D-E1-F0 1 -70
84-24-8D-91-0B-00 Zebra Tech AP25:R1 84-24-8D-8E-2C-10 1 -71
84-24-8D-91-0B-00 Zebra Tech AP26:R1 84-24-8D-8D-E1-F0 6 -71
84-24-8D-91-0B-00 Zebra Tech AP10:R1 84-24-8D-8F-DE-C0 1 -71
84-24-8D-91-0B-00 Zebra Tech ap6521-43C2F0:R1 FC-0A-81-D3-52-A0 1 -72
84-24-8D-91-0B-00 Zebra Tech ap6521-43C85A:R1 FC-0A-81-D3-46-C0 1 -72
84-24-8D-91-0B-00 Zebra Tech AP24:R1 84-24-8D-91-95-40 11 -73
84-24-8D-91-0B-00 Zebra Tech AP24:R1 84-24-8D-91-95-40 1 -73
74-67-F7-78-3D-10 Zebra Tech ap6521-43C5DC:R1 FC-0A-81-D3-46-10 1 -73
74-67-F7-78-48-A0 Zebra Tech ap6521-43C85A:R1 FC-0A-81-D3-46-C0 1 -73
74-67-F7-78-3D-10 Zebra Tech AP12:R1 84-24-8D-8D-CE-00 1 -73
74-67-F7-77-C4-00 Zebra Tech AP10:R2 84-24-8D-8E-CD-A0 36 -74
74-67-F7-78-49-30 Zebra Tech ap6521-43C85A:R1 FC-0A-81-D3-46-C0 1 -74
We are changing the AP density and likely models soon due to some site changes
282 Points
it might be worth looking to amend the smart-rf config
below is an example
sensitivity custom
assignable-power 5GHz max 18
assignable-power 5GHz min 14
assignable-power 2.4GHz min 12
assignable-power 2.4GHz max 18
smart-ocs-monitoring sample-count 5GHz 10
smart-ocs-monitoring sample-count 2.4GHz 15
smart-ocs-monitoring awareness-override schedule 1 23:00 04:00 all
coverage-hole-recovery snr-threshold 5GHz 10
coverage-hole-recovery snr-threshold 2.4GHz 10
coverage-hole-recovery client-threshold 2.4GHz 3
neighbor-recovery dynamic-sampling
the key line is neighbor-recovery dynamic-sampling
when this line is added it is worth running
service smart-rf clear-config
this will reset smart RF it will take between 10-30min for the process to complete
I would recommend upgrading to a supported code base.
GTAC can help with this.
below is an example
sensitivity custom
310 Points
Thanks Andrew,
We had severe issues with coverage-hole and neighbor-recovery but we may not have configured it properly. It worked out much better removing them and that was brought one of our rf-domains to become stable but I will revisit this.
I'm not sure what you mean by a supported code base. Is this just the firmware we are running? We will run the latest (or close to) when we migrate
Related Categories
ExtremeWireless (WiNG)
- 523 Conversations
- 168 Followers
