how to connect to extreme identify wireless c35 by using console port?
  • Problem
  • Updated 5 months ago
  • Solved
ı don't connect this device with admin ports by using console cable
Photo of Hasan Güngör
Hasan Güngör
  • 180 Points 100 badge 2x thumb
  • sad
Posted 5 months ago
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,502 Points 20k badge 2x thumb
Hasan Güngör
I tried this but it does not
Hasan Güngör
yes of course
Photo of Doug Hyde
  • 20,438 Points 20k badge 2x thumb
try rebooting the c35 with the console attached, hit enter a few times after the power cycle to see if anything prints to the screen
Hasan Güngör
it does not work .the another thing is that devices's digital screen has no prints.
Photo of Doug Hyde
I saw that too, sorry this happened. That's why I was hoping you could at least see the bootup cycle and try to recover.
I would contact the GTAC at this point... https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-contact-Extreme-Networks-Global-Tec...
Hasan Güngör
thanks
Photo of Umut Aydin
Umut Aydin, Escalation Support Engineer
  • 2,280 Points 2k badge 2x thumb
Selam Hasan,
try serial port 115200 and it should work.
Regards
Umut Aydin
Hasan Güngör
selamlar,
denedim ancak olmadı.reset attım ama yine olmadı ön taraftaki digital ekranda siyah çizgiler mevcut bu cihazın bozuk olduğunu gösterir mi?
Photo of Umut Aydin
Merhaba,
digital ekrani aletin üretici firmanin kullandigini tahmin ediyorum. Bizim programda/Wifi kullanima kapali onun icin herhangi bir sonuc elde edemiyoruz. Ama hersey denendigine göre aletin degistirilmesinde bence bir sakinca yok. Buna ragmen Case acmaniz lazim orda arkadaslar size yardimci olacaklar.
Iyi isler
Umut Aydin
#########FYI
Changig serail port doesn't work as well .
Please open a case and replace the controller.
