How to get a list of unused ports with Extreme Management Center ?
  • Question
  • Updated 2 days ago
I'm using Extreme Management Center version 8.1.4.40 with base licence. I'm looking for a way to get a listing of unused port for the last 1 year.
I configured a daily task to collect "capacity planning" data but I'm stuck in the generation of a report like Ridgeline software did previously. And the "Capacity Planning" menu in Extreme Management Center's Dashborad just show a red disk indicating 100% not collected...
For the moment, I try to check on demand, device per device, but I loose a lot of time and if the device has rebooted less than 1 year ago then I can't get a useful report.
All my switches are running ExtremeXOS (from version 12.x to the last 22.x).
Does anybody know a way to perfom this ?
Regards,
Romain M.
Photo of Romain Mercier
Romain Mercier
  • 432 Points 250 badge 2x thumb
  • frustrated
Posted 2 weeks ago
Photo of Jeff Roberts
Jeff Roberts
  • 120 Points 100 badge 2x thumb
This command may be helpful - it gives a history of link up/ link down for a port.
show port info detail | inc Port:|Link\sState:|Link\sUps:|Link\sDowns:
Romain Mercier
Thank you Jeff.
That's the command I use. The problem with this command is that it gives the state since the last reboot of the device so you have to take care of the uptime of the device.
I'm wondering if I should enable snmp traps for ports UP/DOWN so Extreme Management Center will have get this information to generate the Capacity Planning ?
Romain Mercier
I found this kind of lines in the server.log of my Extreme Management Center :
168087468       2018-09-10T13:21:10UTC  Inventory Server.4.Event        r.mercier       Inventory Server        172.31.0.229    Archive Save    Archive Save Capacity Planning: (172.31.0.229) Version Stamp: Sep 10, 2018 3:15:00 PM - Warning - The ability to archive configuration files for this device has been disabled. :
I checked the gtacknoledge site :  https://gtacknowledge.extremenetworks.com/articles/Solution/Unable-to-archive-configuration-error-Th...
On my server, this device is set on script for both firmware and configuration download MIB.
This device is a stack of summit x440. And configuration archiving works well.
Could this be a license restriction ?
Photo of Sri
Sri, Employee
  • 80 Points 75 badge 2x thumb
In XMC, we have a couple of reports available for Port usage.  These are all under FlexReports (for any given site).  Please look at the following FlexReports : Device Ports Used or Port Capacity.
Romain Mercier
Thank you Sri.
In this Q&A : https://gtacknowledge.extremenetworks.com/articles/Q_A/What-options-do-I-have-for-NetSight
It's written that reports is include in NMS license, does FlexReport is a feature included in "Reports" ?
My server is running a NMS-base license.
Romain M.
Romain Mercier
Hi there,
After some more research on the web, on the hub etc... I finally found a link to ExtremeNetwork's GitHub.
https://github.com/extremenetworks
There is a part dedicated to NetSight-Reports-View where I found many flexviews. Sorry Sri, all my searches about FlexReport  brought me back to this thread.
One FlexView is called "Port_Status_Time_with_alias" located here : https://github.com/extremenetworks/Netsight-Report-Views/tree/master/FlexView/Networking
This flexview generate a list of all ports from a device, its current status and the elapsed time in this state. You can export data to a CSV file.
The data don't seems to persist accros device's reboot.
Romain M.
