Identity and Access dashboard per appliance group
  • Question
  • Updated 2 years ago
  • Answered
We are configuring multiple nac appliance groups with different rules and end systems per appliance group (wireless guest access, dorm networks, campus networks). I would like to keep these end systems on the reports contained to the specific appliance group they belong to. I currently don't see a way to filter per appliance group on the reports in one view. Is it possible to create separate dashboards per appliance group. I have looked in custom reports and don't see appliance group as an option to filter on.
Photo of Eric Smith
Eric Smith
  • 70 Points
Posted 2 years ago
Photo of Matthew Hum
Matthew Hum, Principal Engineer, APAC
  • 1,542 Points 1k badge 2x thumb
If you want to contain reports you can use Zones to do this. In each appliance group add the rules to it's own zone (you can name it the same as the appliance group). This will then give you a filterable value and you can even restrict specific logins to specific zones.
You can lookup zones in the NAC Manager User guide.
