inter vlan issue
  • Problem
  • Updated 6 days ago
i have 2 networks,these networks are in different core switch,i created different vlans in both switch,now inter vlan is not working what is the solutions
Photo of Ranjith
Ranjith
  • 180 Points 100 badge 2x thumb
Posted 7 days ago
Photo of Naresh
Naresh, Employee
  • 1,296 Points 1k badge 2x thumb
Hi Ranjith,
If core switch is Extreme device, make sure ipforwarding is enabled on both the VLANS.
Photo of Lexus92008
Lexus92008
  • 240 Points 100 badge 2x thumb
HiĀ Ranjith!
It seems to be "enable ipforwarding" and "enable ipforwarding vlan <vlan_name>" is your solution.
Don't forget to place an ip address on both vlans. They mast be from different subnets.
Photo of Mrxlazuardin
Mrxlazuardin
  • 1,534 Points 1k badge 2x thumb
Hi Ranjith,
Don't forget to route between core switches and make static routings for each vlan, or you can use dynamic routing protocol for advertising each vlan network.
Best regards,
Photo of Ranjith
Ranjith
ip forwarding is enabled.route is not configured.can you please explain the route configuration
Mrxlazuardin
Hi Ranjith,
This URL might be helpful.
https://gtacknowledge.extremenetworks...
Best regards,
Photo of Lexus92008
Lexus92008
Where links between core switches. What configuration they have?
