Is possible to collect Rejected IP and Ports with snmp?
  • Question
  • Updated 2 years ago
  • Answered
I want to collect "Rejected IP" + "Rejected Port" from problematic X350.
Is possible get this information with snmp or other method?
Additional Q: if I create ACL to deny unwanted subnet on "Rejected port", Is this deny connection count only on 'show access-list counter' or included also in "Rejected IP" and "Rejected Port" (read: show iparp stats vlan all) ?
I got many rejected counts and because I want start debug collect it to start debug my network incorrect design.
excuse about my bad English and networking knowledge...
Photo of modris bernands
modris bernands
  • 610 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Ron Huygens
Ron Huygens, Employee
  • 3,210 Points 3k badge 2x thumb
As far as I know, these values are not available in any SNMP MIB.
The ACL counters are only shown with 'show access-list counter' and will not show up in any other system counter.
Photo of Kevin Kim
Kevin Kim, Employee
  • 2,266 Points 2k badge 2x thumb
You can allow ARP packets having a sender address within a network subnet configured and deny everything else. You would see ACL deny counter increasing but not see the rejected counter increasing in the show iparp output.
entry 1 { if { arp-sender-address 10.0.0.0/24; } then { permit; } }
entry 2 { if { arp-sender-address 0.0.0.0/0; }     then { deny; count denyarp; } }
modris bernands
Thats is what I need, work greate and block all unvanted ARP.
modris bernands
What ir Yours documental library for <match-conditions> in ACL? Is there place where it all together, for example, rfc?
I try find some similaries with wireshark filters, but not sure. Or is this only defined and implemented by extreme designers?
Photo of Kevin Kim
Kevin Kim, Employee
Please check 'Chapter 20 ACLs' in the EXOS 15.3 Concepts Guide.
http://extremenetworks.com/wp-content/uploads/2014/03/EXOS_Concepts_Guide_15_3_2.pdf
modris bernands
I found what i ask. I just need more RTFM, sorry.
Thank You.
