OSPF v3 Test Procedure
Waqas_Naeem
New Contributor II
Is there test procedure for OSPFv3 on Summit switches?
7 REPLIES 7
Erik_Auerswald
Contributor II
Hi Waqas,
you might want to take a look at the documentation for OSPFv3. For testing you probably need two switches with the respective licenses, a network cable between them, and then configure basic OSPFv3 in the Default VLAN. Adding IP addresses, enabling ipforwarding, enabling OSPFv3, and adding vlan Default to OSPFv3 should suffice. You could then use the commands starting with show ospfv3 to verify operation.
Erik
Waqas_Naeem
New Contributor II
Basically equipment is in customs and they need to perform test procedure for OSPF v3 before approving the clearance and release
This is the first time I heard this so thought to ask on community. I will try to get details and will surely share here
Neither do I. Doesn't make sense to me.
Waqas, could you please clarify?
Thanks.
