Recommended configuration for AP8533 Gigabit Port?
  • 2
  • Question
  • Updated 5 months ago
  • Answered
Hello Community,
We are deploying AP 8533 access points and are looking for the best practice on port configuration between the access point and the switch. The majority of the access points we have now only have a single gigabit connection and we simply treat them as a trunk port and set the native vlan to an AP management vlan. No user traffic is tunneled back to the controller.
What are other people doing with the second gigabit port on the AP8533?
We have attempted to configure it as a port channel from the controller only to be told "No channel-group support on device type ap8533". Based on this error message I found this page which indicates that is not a supported configuration.
Any help would be appreciated
Photo of Theodore Chandler
Theodore Chandler
  • 180 Points 100 badge 2x thumb
Posted 5 months ago
  • 2
Photo of Mathew Sebastian
Mathew Sebastian, Employee
  • 94 Points 75 badge 2x thumb
We have the link aggregation supported in the release 5.9.2.0 on APs with two gig interfaces. You may upgrade the firmware and use the feature if required.
usually, people may use the second interface for a wired client or service.
Photo of Vedran Jurak
Vedran Jurak
  • 1,078 Points 1k badge 2x thumb
Looking at the config, I'm seeing source/destination MAC or source/destination IP.
Theodore Chandler
Ok, thanks for the information. Looks like we will just not use that port as we can not upgrade at the moment due to legacy AP650's.
Vedran Jurak
Which version are you running at the moment?
Theodore Chandler
We are running 5.9.1.5-001R which I've been told is the last version to include firmware for the AP650.
Vedran Jurak
Just checked on one VX, and yes, the AP650 is gone.
