Routing configuration to forward multicast traffic to a tunnel interface
  • Question
  • Updated 2 years ago
  • Answered
Hi all,
I have a L3 network topology where the core network segment doesn't support IP Multicast protocols.
As such, I have configured a couple of X460 switches/routers in order to provide an end-to-end GRE tunnel able to encapsulate Multicast traffic without the need for IGMP/PIM (no control on the core network routers).
I expected to force Multicast traffic to be routed through the GRE tunnel interface by configuring a route in a similar way I'm used to do with Linux, e.g.:
        add route -net 239.0.0.0 netmask 224.0.0.0 dev my_tunnel_gre
Unfortunately, I haven't found a command in the manual to configure such a route on ExtremeOS.
Does anyone have any idea how to achieve such a behavior?
I appreciate any answers able to solve the above issue.
Thank you.
RB,
Luca.
Photo of Luca Spinacci
Luca Spinacci
  • 216 Points 100 badge 2x thumb
  • confused
Posted 2 years ago
Photo of Kawawa
Kawawa, GTAC
  • 3,272 Points 3k badge 2x thumb
Hi Luca, I don't think EXOS allows you to specify a Class D address in a route.  I'll need to verify that.  However, you can add a multicast route to the routing table using the following command:
configure iproute add <unicast subnet/mask> <gateway> multicast
configure iproute add 70.0.0.0/24 70.0.0.254 multicast
This tells the router to forward all mutlicast streams originating from the 70.0.0.0 subnet via the interface 70.0.0.254, which would be the destination address of your GRE tunnel.  And because, this is a static route, it will have precedence over any dynamic routes that may exist to the same destination.
I hope this is what you're looking to implement
Luca Spinacci
you're right, Class D addresses are not allowed by EXOS.
The Multicast route you suggested seems to satisfy my request.
Is there a way to apply it to separate Multicast streams (e.g. 239.0.0.0, 224.0.0.0) in order to allow, for instance, data traffic instead of routing control plane information through the GRE tunnel?
Thank you very much for your precious help.
Luca.
Luca Spinacci
I tried the above configuration.
If I correctly understood the behavior of the Multicast route, supposing of having the subnet 70.0.0.0/24 configured to belong to an OSPF Area 0.0.0.0, I would be able of forwarding OSPF Hello messages addressing the IP Multicast address "224.0.0.5" on the other side of the tunnel.
Strangely, this doesn't seem to happen as the OSPF router at either side of the tunnel does not see any neighbor.
 How come?
Where are my assumptions wrong?
Thank you.
Luca.
Photo of Kevin Kim
Kevin Kim, Employee
  • 2,266 Points 2k badge 2x thumb
I don't think the current EXOS implementation supports mulitcast forwarding over GRE tunnel.
Limitation
• IPv4 only (both the routed traffic, and tunnel protocol)
• Unicast forwarding only, no Multicast
• Single IP address can be configured on a GRE tunnel
• Duplicate Address Detection (DAD) not supported
• No routing protocol support (RIP, OSPF, etc. etc.), only static routes
• Software based forwarding
Photo of Eugene Paniot
Eugene Paniot
  • 186 Points 100 badge 2x thumb
