Run Script on Discovery during ZTP+ process
  • Question
  • Updated 7 months ago
  • Answered
  • (Edited)
Dear all.
I have a question about running a script during ZTP+ process.
NetSight 8.0.4.54
EXOS 22.3.1.4 Patch 4
We want to deploy ZTP+ functionality. The overall process is working fine.
Devices are discovered. Firmware is updated and the devices are integrated automaticaly to the correct site in EMC.
What I want, is that a new device gets a special basic configuration after it is discovered.
In the settings for every site in the menu "Discovered Device Actions" you can add a script.
I can add the script, but it is not executed. I did not find some detailed information in any manual about this functionality.
So can anyone help me here to get this running!?
thanks and best regards
Alex
Photo of aloeffle
aloeffle
  • 934 Points 500 badge 2x thumb
Posted 8 months ago
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,474 Points 5k badge 2x thumb
save the script as JSON-RPC and you should be good.
Z.
Photo of aloeffle
aloeffle
Hi Z.
thanks for your fast reply. I did so, but without success.
Can you please give me more details!?
I also checked the event log. It seems that the script is not executed at all. Neither CLI nore JSON-RPC.
regards
Alex
Photo of Grosjean, Stephane
Grosjean, Stephane, Employee
  • 12,582 Points 10k badge 2x thumb
it should work with any script. How do you create your script? It needs to be valid.
Photo of aloeffle
aloeffle
Hello Stephane.
thanks for your help
I create the script by
Administration ->Scripting -> Scripts -> Add ...
If I run this script manualy on a device, it is working.
To avoid script errors, I only configure a sysname in my test lab.
configure snmp sysname "ingolstadt"
regards
Alexander
(Edited)
