Site Maintenance on SW downloads
  • Problem
  • Updated 1 year ago
  • Solved
For the last 4 days I'm unable to access any EXOS Downloads. "Site Maintenance" - "Please try again later."
Is this just me? Any ETA on returning to service?
Photo of Sebastian Maurer
Sebastian Maurer
  • 70 Points
Posted 1 year ago
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Sebastian,
We are sorry for the inconvenience but a lot of the features on the support portal are still under maintenance. As of now there isnt an ETA but it is being actively worked on and updates may be provided on the page below:
http://support.extremenetworks.com/
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,266 Points 3k badge 2x thumb
Hi Sebastian,
My sources are telling me sometime in the next hour or so.
Thanks
Brad
Photo of Brandon Clay
Brandon Clay, Escalation Support Engineer
  • 13,086 Points 10k badge 2x thumb
Hi Sebastian,
This link should give you some more info on the maintenance that is currently ongoing.
http://www.extremenetworks.com/esupport-transition/
-Brandon
Photo of Stephen Elliott
Stephen Elliott
  • 1,034 Points 1k badge 2x thumb
doesn't work for me either - resetting password just loops as well
Photo of Ryan Mathews
Ryan Mathews, Alum
  • 8,988 Points 5k badge 2x thumb
Stephen, Were you able to log-in to the portal?
I did confirm you have an account created.
Please let us know if you're still having trouble.
(Edited)
Stephen Elliott
yes I can, thanks Ryan...  the password reset screen doesn't acknowledge that you've asked for a reset and the emal took about 10 mins so I thought it wasn't working.  all good now though.
Ryan Mathews, Alum
Glad you were able to log in to the Extreme Portal Stephen.  Once again, I'm sorry for the frail process that you had to endure to get access to the new site.
I'm afraid this is a temp process that will be replaced with a more robust self-service user registration/profile management on the portal in the coming weeks.
We'll keep working to accelerate a proper solution.  I hate that you ran in to so many dead ends.
