ssh module not loaded, set xmod imag as primary?
  • 2
  • Question
  • Updated 8 months ago
  • Answered
  • (Edited)
set the image as primary, actually am facing an issue with ssh "module not loaded" after i have checked the switch i found xmod image not set:
# sh version images
Card Partition Installation Date Version Name Branch
Switch primary Thu Nov 24 12:31:55 UTC 2016 15.5.4.2 nwi-15.5.4.2-4.xos v1554b2-patch1-4
Switch secondary Thu Nov 24 12:16:32 UTC 2016 15.5.4.2 nwi-15.5.4.2-4.xos v1554b2-patch1-4
Switch secondary Thu Nov 24 12:17:32 UTC 2016 15.5.4.2 nwi-15.5.4.2-patch1-4-ssh.xmod v1554b2-patch1-4
is it possible to set xmod imag as primary?
Photo of chahid
chahid
  • 80 Points 75 badge 2x thumb
Posted 8 months ago
  • 2
Photo of Patrick Voss
Patrick Voss, Employee
  • 11,474 Points 10k badge 2x thumb
Hello Chahid,
The ssh xmod has to be loaded individually. Since you have the same image on both the primary and secondary you can simply boot into the secondary image and the ssh xmod will load automatically.
Photo of Bin
Bin, Employee
  • 5,350 Points 5k badge 2x thumb
Hi chahid,
You could also try to use EXOS 16.2, 21.x, or 22.x.
It is because that starting in EXOS 16.2, 21.x and 22.x the SSH module is integrated into the standard EXOS image.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Where-is-the-SSH-module-for-EXOS
Best regards,
Photo of Vellachery, Sumeesh
Vellachery, Sumeesh, Employee
  • 3,268 Points 3k badge 2x thumb
Chahid,
As stated by Patrick, boot the switch to the secondary partition and check the status of the SSH access is Enabled in "show management".
In case, if it isn't Enabled. Execute the command "run update" and then "enable ssh2" and check the SSH access.
