Study Guide
  • Question
  • Updated 2 years ago
  • Answered
Hi guys,
I'm a newbie in this extreme network product lines. I need your help/suggestion/guide. I need some reference books,guide,lab so that I can familiarize myself with the XOS command. Any suggestion?
Thank you so much in advance.
Photo of hafiz
hafiz
  • 196 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,782 Points 10k badge 2x thumb
you can build your own lab using the EXOS VM from https://github.com/extremenetworks/Virtual_EXOS. The EXOS User Guide provides a good starting point for your studies: http://documentation.extremenetworks.com/exos/index.html. A Command Reference Guide is available as well: http://documentation.extremenetworks.com/exos_commands/index.html.
Best regards,
Erik
Photo of Drew C.
Drew C., Community Manager
  • 37,366 Points 20k badge 2x thumb
Hi hafiz, welcome to The Hub!
In addition to the documents (and VM) Erik mentioned above, check out the EXOS Quick Guide.
Don't forget about the GTAC Knowledgebase.
You're welcome back here if you have any questions!
Photo of Kevin Kim
Kevin Kim, Employee
  • 2,266 Points 2k badge 2x thumb
If you have a support portal account, we also can find e-learning courses in 'Training and Certifications' of 'my support' page
Below and more courses are available.
ExtremeXOS Fundamentals
ExtremeEOS Fundamentals
Photo of hafiz
hafiz
thanks for all the replies.my "extreme" journey will begin now :)
Photo of hafiz
hafiz
other than that...is there any lab manuals that I can follow so that my personal training will be more effiecient?
