Updating firmware on a X430-8p switch.
  • Question
  • Updated 2 years ago
  • Answered
Hello Everyone,
Lets start out by saying "I am new to using Extreme Networks Switches. To tell the truth I am a novice to Networking all together. Never used a managed switch at all. I am an Audio Engineer. We have purchased the X430-8P for a small Biamp Tesira AVB System. This is just a single switch configuration.
Here is how my issue started: I have 6 end points and found out while hooking the system up I run out of Inline-Power (POE). I can only hook up 4 end points. I found that the X430-8P is defaulted to 60W but can be configured for 90W. I found the command "configure inline-power budget" but I get an "Invalid Input detected |^|" at the "b" in budget. Upon more searching I found out that this command is not available on my version of firmware 15.5.3.4. This command is on version 15.7 and above.
Now for my issue: I can find all sorts of Release Note but no firmware. What file extension am I looking for? I believe it is ".xos", I just don't see it.
Sorry for being long winded,
Thank you,
Brian S. Florey, CTS
Photo of Brian Florey
Brian Florey
  • 100 Points 100 badge 2x thumb
Posted 2 years ago
Photo of David Coglianese
David Coglianese, Embassador
  • 7,388 Points 5k badge 2x thumb
From the home page click on support > software
Then the first blue link should get you there, but you will have to login.
I am fairly certain that switch runs summit lite not full xos
Hope that helps.
Photo of Brad Parker
Brad Parker, Technical Support Engineer
  • 3,836 Points 3k badge 2x thumb
Just confirming the X430 does indeed run the summitlite images.
Photo of Drew C.
Drew C., Community Manager
  • 40,694 Points 20k badge 2x thumb
Brian, I'd recommend going to the very latest version of code for your X430.  At present, the file you'll want is summitlite-16.1.3.6-patch1-8.xos (patch1-9 is due soon).
This article will help you find it:  How to obtain a copy of the EXOS software and upgrade EXOS switches
I should also ask if you were sold an AVB license when you purchased the switch?  This is required to enable AVB.
(Edited)
