Using TLS Certificate fields for authentication mapping
  • 2
  • Question
  • Updated 2 days ago
  • Answered
  • (Edited)
Hello,
can I use TLS certificate fields like "TLS-Cert-Issuer" or "TLS-Cert-Common-Name" (or other fields mentioned here: https://gtacknowledge.extremenetworks.com/articles/Solution/Using-TLS-Certificate-fields-for-authent...)  to do the authentication mapping in the NAC AAA configuration to e. g. switch between local authentication or proxy radius if I use 802.1x?
If yes, how can I do set? What do I have to enter in the fields (User/MAC/Host)?
Best regards
Stephan
Photo of SH
SH
  • 2,396 Points 2k badge 2x thumb
Posted 2 weeks ago
  • 2
Photo of Shmulik
Shmulik, Employee, PLM for ExtremeGuest and ExtremeControl
  • 192 Points 100 badge 2x thumb
Stephan, are you looking to use a cert field for making a decision if to proxy the request to another server or auth locally? or are you looking to perform the auth by ExtremeControl server but use a cert field to make an authorization decision as what network service to assign?
Photo of SH
SH
Hello Shumlik,
I want to make a decision if to proxy or do a locally auth.
Best regards
Stephan
Photo of Pala, Zdenek
Pala, Zdenek, Employee
  • 8,474 Points 5k badge 2x thumb
Hi Stephan.
the decision to proxy or not can be made based on Location (Switch, Port, SSID, AP, Zone), based on username (pattern or group membership, in case of certificates the name is CN), based on authentication type.
I suggest to terminate EAP-TLS locally and add more CA and more CRL to your configuration. The Access Control Engine can authorize based on more CA.
Regards
Z.
Photo of SH
SH
Thank you Pala,
can I use only parts of the certificate CN, too? Like "host/*" in an user name.
Best regards
Stephan
Yes you can use wildcard to check the username. Username is the CN.
Photo of SH
SH
Thank  you Pala.
Photo of Anton Sax
Anton Sax
  • 978 Points 500 badge 2x thumb
I can only show a screenshot in OneView.
You can make a User Group and Change it to RADIUS User Group, then you can rely on TLS Attributes.
We did it with TLS-Client-Cert-Common-Name, but others should also be possible.
Does anyone has a list of which attributes are possible?
Photo of SH
SH
  • 2,346 Points 2k badge 2x thumb
Hello Anton,
you will see the attributes in the KB article following the link in my first text above.
Best regards
Stephan
