what is the command on extreme switch to move from execution level to configuration level
  • Question
  • Updated 11 months ago
  • Answered
Extreme switch is under TACACS authentication and I could not move from execution level (>) to configuration level(#) . see below commands and error
Slot-1 NEOS-PS-FWswitch.6 > show configuration
This user does not have permissions for this command.
My question : what is the way to move from one level to next level?
Photo of Suirnder Pal
Suirnder Pal
  • 90 Points 75 badge 2x thumb
Posted 11 months ago
Photo of Alexandr P
Alexandr P, Embassador
  • 12,670 Points 10k badge 2x thumb
Hello!
You have to correctly configure privileges (level 15) in TACACS+ server.
Thank you!
Suirnder Pal
Does it mean that there is no equivalent command to go configuration mode like in case of cisco
"enable"  ?
Photo of Frank
Frank
  • 3,776 Points 3k badge 2x thumb
On EXOS switches, once logged in, you're in "enable" mode - it's like some cisco devices where your username is automatically in 'enable'
Looking at the message that comes back, that's coming from the TACACS server telling you "you're restricted". As Alexandr said, you'd need to set the appropriate command rights and/or levels for your user on the TACACS server's config.
As a last resort, turn off the tacacs server, and log in with the locally defined admin user on the switch ;) At least on my switches, if tacacs isn't available, it falls back to local users - but ONLY if the tacacs server isn't available.
   Frank
Suirnder Pal
thanks to update .
