x440-24t vs c5g124-24 for edge router
  • Question
  • Updated 3 years ago
  • Answered
We save S4 chaisis as core. And using one C5G124-24 per building as edge routers. And A4H series for access switches.
Our local partner said as a result of Extreme/Enterasys merge we should invest in summit X series instead of enterasys gears. X430 in place of A4H will be a good replace for us as it is 1G switch. But for our new building should we use X440? Do they have comparable parformance/features for our use case?  We use dual stack ipv4 and ipv6 static routing on edge routers.
Rahman
Photo of Rahman Duran
Rahman Duran
  • 2,012 Points 2k badge 2x thumb
Posted 3 years ago
Photo of Curtis Parish
Curtis Parish
  • 3,332 Points 3k badge 2x thumb
Sounds like you need a new partner.     We have been told the roadmap for current enterasys products will continue.   No clue about what they are designing  jointly for the next generation but your partner is assuming a lot to say it will be a X series.
Photo of Lane, Mike
Lane, Mike, Employee
  • 904 Points 500 badge 2x thumb
Rahman, Though you can still purchase the A/B/C series switches and they will be supported for quite sometime, it is a good idea to take a look at the Summit X-series as it is the platform going forward in the long term.  The X430 and X440 both support IPv6, but it should be noted that only the X440 and above support routing.  Role-Based Policy is supported on the X450-G2 and above as well.  I do recommend you consult with your partner and if you have any further questions, I can get you in touch with your local Extreme Pre-Sales Engineer.
- Mike Lane, Extreme DACH Pre-Sales
Curtis Parish
Mike that is very interesting information that is contrary to what we have been told.    Has Extreme released a roadmap showing the X is replacing the A/B/C series?
Photo of Bill Stritzinger
Bill Stritzinger, Alum
  • 6,036 Points 5k badge 2x thumb
Curt,
The updated roadmap on the edge is to transition from A/B/C to Summit X series. The X450-G2 product that was released on June 15th is the transition product for the B/C product as that release also included XOS 16.1 which now has full policy support.  Let me know if you have any questions.
Bill
Rahman Duran
Thank you for the clarification.
