X450e-48p routing all multicast traffic to other switch
  • Question
  • Updated 1 year ago
  • Doesn't Need an Answer
I've all my devices running on switch1 X450e-48p "ExtremeXOS version" switch. All of its ports are filled when i added another switch (switch 2) with same os and model behind switch 1 all the multicast traffic from switch 1 to switch 2 is being forwarded on uplink port between switches.
Kindly help to fix this behavior.
Photo of Asim Hafeez
Asim Hafeez
  • 70 Points
Posted 1 year ago
Photo of Jeremy
Jeremy, Embassador
  • 9,788 Points 5k badge 2x thumb
Photo of Kawawa
Kawawa, Employee
  • 2,914 Points 2k badge 2x thumb
What kind of multicast traffic are  you seeing?  Control traffic i.e. PIM exchanges between routers if configured or actual data streams? A multicast stream will not reach an upstream vlan unless there is a host requesting the stream in that destination vlan OR if you have turned off IGMP snooping.
