XOS Extreme Analytics Integration Guide
  • 2
  • Question
  • Updated 2 years ago
  • Answered
Is there an official  guide available for IPFIX / MirrorN / Analytics on XOS (X460-G2) ??
Photo of Holger Gmerek
Holger Gmerek
  • 362 Points 250 badge 2x thumb
Posted 2 years ago
  • 2
Holger Gmerek
So is there no guide for this feature or does no one know ??
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,846 Points 20k badge 2x thumb
(Edited)
Holger Gmerek
Thx Ronald,but this is only for IP-FIX flow registration in Netsight, not mirroN for packet mirror to purview.
I hope that the first one also applies to a X460-G2....
https://gtacknowledge.extremenetworks.com/pkb_Home?q=mirrorn&l=en_US
Holger Gmerek
Unfortunately as the article states, its only for S/N/K - Series
Photo of Dudley, Jeff
Dudley, Jeff, Employee
  • 934 Points 500 badge 2x thumb
Correct the x460G2 is not currently supported within the Analytics solution.
Photo of Patrick Koppen
Patrick Koppen
  • 750 Points 500 badge 2x thumb
Are you sure?
https://community.extremenetworks.com/extreme/topics/summit-x460-g2-and-purview-it-is-possible
"The X460 and X460-G2 now (in code level 15.4 and above) fully support IPFIX and in 16.1 now have the n-mirror capability as a beta, although things work just fine but you will not get any support from TAC. In 16.2 the code will be GA, meaning that if you call TAC you will get support if you need it."
Hi Patrick,
Yes I am sure.  From a support perspective the 460 doesn't provide an adequate solution for an enterprise environment.  It can be used in a test/troubleshooting manner but not meant for full support.
Patrick Koppen
Hi Jeff,
Thanks for the clarification. So this feature is only for lab/testing and not
for production... And even in lab the gre-tunnel oder rspan wouldn't work.
Hi Patrick,
The smaller flow cache on the switch and the lack of GRE tunnel for the mirror traffic to feed the purview appliance our two of the biggest issues I understood.
Perhaps in future releases the use of IPFIX will be used here......
Thanks
Jeff
