‎09-17-2018 01:59 PM
Solved! Go to Solution.
‎09-17-2018 03:12 PM
Thank you for that tech data. I sent you details on what we found in there, but related to your post: the wifi0 radio had no interference to speak of, other than a couple loud neighbors (one of which is using channel 4, but that's not an Aerohive AP so I doubt you have control over it).
Looking at the buffered log it looks like the AP is moving between 15-17 for the power settings, but I'm not seeing any problems per say around that, just that they did a scan and chose that power. Is there a reason to have these APs on auto settings, or would we be able to set the power statically?
‎09-17-2018 03:41 PM
That'll definitely be part of the problem! In that case you might be limited to 2.4GHz. With the current packet failure rate it would be safe to say that 5GHz is unusable in that environment, at least until we could lower those CRC failures.
‎09-17-2018 03:37 PM
Thanks,
Frank
‎09-17-2018 02:53 PM
Another option would be to view the power settings and ACSP info from neighboring APs on their 2.4 GHz radios and lowering the max transmit power. You're probably experiencing a lot of interference in the 2.4 GHz spectrum, particularly since there are only three channels in play.
What we have done is clone the default radio profile, then lower the Maximum Transmission Power in order for ACSP to perform its job more effectively. While you're at it, you could also turn on Band Steering to encourage clients to connect on 5GHz rather that 2.4 GHz.
In most instances we built our coverage based upon 5GHz predictive heat maps and thus reduced our 2.4 GHz max transmit power to 10 dBm.
