AP WiFi1 not running at selected power
‎10-07-2019 04:39 PM
I have several APs (250 and 150W) that have power selected for radio WiFi1 at 14. Most of the AP's are fine but 20% of them are running at 9 instead of 14.
I can't seem to figure out what is going on. The switch seems to be well below power budget and the power selector is the same as the ones that are working properly. 9 is what our bottom wattage (do not drop below) is set to, bud shouldn't they be running on what was selected?
‎10-08-2019 03:43 PM
Are you based in Canada? What is the country code for the APs that are showing the correct power level?
‎10-08-2019 03:38 PM
Country code: 124,
Warning: Power 14 exceeds HW limit(regulatory 9, board 21), forced to 9
‎10-08-2019 03:34 PM
Hm not the channels I'd expect! What's the country code of the APs (show boot-param) by CLI?
Additionally if you do a interface wifi1 radio power 14 on the CLI what's the message you get back from the AP?
‎10-08-2019 03:24 PM
The channels are set to our engineering specs
‎10-08-2019 03:23 PM
40,44,48,52,36,60
Very interesting.. they are all lower numbers. Definitely looks related. Most of the ones that work are triple digits
