‎03-01-2019 02:18 PM
‎03-05-2019 04:26 PM
I was able to get AT power running on the AP550's by using the following command:
"no lldp config <port#> dot3TlvEnable poeplus_config" as of right now it is stable.
This is were I found the information:
https://www.reddit.com/r/networking/comments/4dl6rv/hp_2530_2448_port_poe_not_delivering_poe/
This essentially disables LLDP PoE+ negotiations and the AP will detect 802.3at power during initial PoE negotiation vs doing it via LLDP. I don't feel this is a complete solution as I want LLDP to work. I will continue to work with HP to figure out why this command is needed.
Thank you,
‎03-04-2019 07:08 PM
You could also try to manually set the tx/rx chains in the CLI of the AP. I do not have an AP550 at my disposal today to compare results against.
CLI Commands:
radio profile <wifi1 radio profile name> transmit-chain <1-4>
radio profile <wifi1 radio profile name> receive-chain <1-4>
I have an AP250 though connected to an SR2208 switch and my show system power status shows AT.
What happens if you run the following command: system-power-mode 802.3at
‎03-04-2019 06:31 PM
I set the max to 30W and left LLDP on. I also tried LLDP off and no matter what the AP550 was still on AF power.
‎03-04-2019 04:25 PM
Interesting. The switch shows it as a class 4 device (.3at POE). But the AP shows it as .3af.
Can you hard set the max allowable power on the ethernet port to 30W? Thats the max for .3at POE - https://en.wikipedia.org/wiki/Power_over_Ethernet
Also if you got lldp enabled on the AP a show lldp nei should also confirm what we're seeing.
‎03-04-2019 04:16 PM
AP550 is plugged into port A2.
‎03-04-2019 03:31 PM
It doesn't look like you have LLDP enabled. Just put in the command "lldp" and hit enter. Wait ~60 seconds (LLDP exchanges info every 30 seconds) and do the show lldp neighbor command again.
