AP550's are running in AF power mode.
adam_clegg
New Contributor III
1 ACCEPTED SOLUTION
adam_clegg
New Contributor III
I was able to get AT power running on the AP550's by using the following command:
"no lldp config <port#> dot3TlvEnable poeplus_config" as of right now it is stable.
This is were I found the information:
https://www.reddit.com/r/networking/comments/4dl6rv/hp_2530_2448_port_poe_not_delivering_poe/
This essentially disables LLDP PoE+ negotiations and the AP will detect 802.3at power during initial PoE negotiation vs doing it via LLDP. I don't feel this is a complete solution as I want LLDP to work. I will continue to work with HP to figure out why this command is needed.
Thank you,
23 REPLIES 23
JA
New Contributor III
Hi Adam
Did you ever get a resolution for this from HP?
Thanks
J
adam_clegg
New Contributor III
Thank you,
AnonymousM
Valued Contributor II
Here is lldp neighbor returned from an AP250. It is plugged into an Aerohive SR2208 switch:
> show lldp nei
LLDP neighbor table: Total number = 1
Incoming Port: eth0
Chassis ID(mac address): b87c:f201:0290
Port ID(interface name): 1/0/2
Hold time(seconds): 110
System name: BP-SR2208P
802.3 Power Via MDI:
MDI Power Support: 0x0f
Port Class: PSE
PSE MDI power: supported
PSE MDI power enabled: yes
PSE pairs control ability: yes
PSE power pair: signal pair
power class: class 4
power type: type 2 PSE
power source: primary power source
power priority: low
PD requested power: 154
 PSE allocated power: 154
802.3 MAC/PHY status:
auto-negotiation support/status: 0x03
auto-negotiation: supported
auto-negotiation: enabled
PMD auto-negotiation: 0x1
Bit on: 1000BASE-T full duplex
MAU: Unknown type(0)
TIA - Media Capabilities:
Capabilities: 0xb
LLDP-MED capabilities
network policy
extended power via MDI - PSE
Device Type: Network Connectivity
On a Ruckus ICX-7150-C12P, I simply did the command "lldp run" to enable it globally on my switch stack. On the Aerohive switch I also just enabled it without any extra configuration.
adam_clegg
New Contributor III
Brian,
Two questions:
  1. When using the command "show lldp neighbor" what should the results be?
  2. On your Ruckus switch could you tell me what you lldp settings are?
Thank you,
