ā03-01-2019 02:18 PM
ā03-05-2019 04:26 PM
I was able to get AT power running on the AP550's by using the following command:
"no lldp config <port#> dot3TlvEnable poeplus_config" as of right now it is stable.
This is were I found the information:
https://www.reddit.com/r/networking/comments/4dl6rv/hp_2530_2448_port_poe_not_delivering_poe/
This essentially disables LLDP PoE+ negotiations and the AP will detect 802.3at power during initial PoE negotiation vs doing it via LLDP. I don't feel this is a complete solution as I want LLDP to work. I will continue to work with HP to figure out why this command is needed.
Thank you,
ā03-04-2019 07:45 PM
I understand what you said about LLDP and the wifi1 interface.
ā03-04-2019 07:42 PM
Can you also provide the output of the following command: "show run | i SCPS_NAC_wifi1"
The LLDP = N/A is saying that LLDP is not setup on that interface (wifi1). If you were doing a mesh network where another AP was bridging to your LAN off of this interface, you would see that neighbor in the LLDP table.
ā03-04-2019 07:40 PM
Interesting that I have LLDP on at the switch but the AP is showing LLDP N/A.
ā03-04-2019 07:37 PM
Those are the default radio profiles that are applied to hardware out of the box. I show those on my AP250 even though I have different radio profiles attached to the respective interfaces.
Can you show the output of a "show interface wifi1" command?
ā03-04-2019 07:34 PM
I found something interesting when doing a show radio profile. Do 1 and 2 look correct to you?
