AP550's are running in AF power mode.
adam_clegg
New Contributor III
1 ACCEPTED SOLUTION
adam_clegg
New Contributor III
I was able to get AT power running on the AP550's by using the following command:
"no lldp config <port#> dot3TlvEnable poeplus_config" as of right now it is stable.
This is were I found the information:
https://www.reddit.com/r/networking/comments/4dl6rv/hp_2530_2448_port_poe_not_delivering_poe/
This essentially disables LLDP PoE+ negotiations and the AP will detect 802.3at power during initial PoE negotiation vs doing it via LLDP. I don't feel this is a complete solution as I want LLDP to work. I will continue to work with HP to figure out why this command is needed.
Thank you,
23 REPLIES 23
adam_clegg
New Contributor III
Is show lldp neighbor the entire command? If it is its not showing any tables. AP550's are running 8.4r10 on HM Cloud.
AnonymousM
Valued Contributor II
Adam,
Can you paste in a show lldp neighbor output from one of the AP550s from the CLI? It should show you the requested POE (PD requested power: xx as well as the PSE allocated power: xx). Curious what the AP is asking for. Also, what HiveOS are the running?
adam_clegg
New Contributor III
I tried searching but this was the only issue with AT and AF I could find and the issue was never resolved or posted. https://thehivecommunity.aerohive.com/s/feed/0D50c00006BNg9xCAD
adam_clegg
New Contributor III
 TX/RX chains are 2x2. We have HP/Aruba 5406 and 2930's. I've tried forcing the AP to AT mode and I've tried to manually set the POE values on the switch and making the ports critical.
Any help to get them on AT power would be greatly appreciated.
