‎02-14-2020 09:38 AM
Anyone have any success in having a AP630 working without giving a insufficient power error in the portal? With Procurve switches? I can get rid of the error by forcing the AP from Auto to AT , but it is cleared when i update the network policy. But should it not be possible for the AP to negotiate a proper power setting without showing insufficient power error in the portal?
I have tried a bunch of settings on the switch, but the LLDP negotiation does not seem to work properly.
I found this one (it is identical to my issue), but this is not a solution, but a workaround. Optimally the AP and Switch should figure this out by themselves.
‎02-14-2020 11:34 AM
I've the same problem with AP650s on Cisco Catalyst 4510R switches with old and acutal IOS image. You can use firmware release 10.0r3 u. 10.0r4 then the PoE+ (802.3at) is working properly. No fix with firmware 10.0.r8.
The APs working with correct power on Cisco Catalyst 9400 and C3560. Maybe a problem in the LLDP paket?
‎02-14-2020 10:48 AM
By the way, this has been tested on the latest 10.0rx firmwares, including r8
