Clients are disconnected when roaming between ap
angel_sardon_ma
I have a problem with AP130. I have 4 and my clients are disconnected each time that they change of AP.
I dont know if it is a problem of roaming, if I must configure AP as DHCP servers....
I only could see that in the client information show a red dots in "defalt gateway ARP" and "DNS". Could be related? (I attach a screen shot)
When the client is disconnect the only way for reconect it is disable/enable the wifi in the end point user.
Any help will be welcome.
Thanks
1 ACCEPTED SOLUTION
samantha_lynn
Esteemed Contributor III
Thank you for that organization name. I was able to take a look at your configuration which all seemed fine, and then I noticed we were seeing some heavy interference on both radios. I emailed you the details, but we'll want to start working on cleaning up the airspace so we can fully pass traffic.
@Nam Nguyen Thac​ , if you would like to send me tech data I can let you know what your interference levels look like. If you'd like to try troubleshooting RF interference on your own, here is a guide that can help with that- https://thehivecommunity.aerohive.com/s/article/Radio-Frequency-Interference-NG
8 REPLIES 8
nessar
Dear Sam,
I am also experiencing the same roaming problem.
how to get report like angel's ?
samantha_lynn
Thanks very much for giving me access. I just want to be sure I'm looking in the correct instance, can you confirm your Organization Name for me? You can find this in the HiveManager if you click on the silhouette icon in the top right hand corner> Global Settings> Account Details.
angel_sardon_ma
Thank you very much.
Done!! [email protected] is add to HiveManager
Thanks in advanced
samantha_lynn
You don't need to set your APs up as DHCP servers so long as you have DHCP on your backend, which it looks like you do. There are a few settings that can help with roaming, and I'd like to take a quick look at your current configuration. Would you be able to add [email protected] to your HiveManager as an external user? No changes will be made without your express, prior permission, I just want to take a look around your current setting to see what we're starting with here.
