Does HiveManager support using LDAP for WIFI ssid authentication?
bluegrass-168
HI GUYs,
Any one know that does Hive-manager support using LDAP for WIFI ssid authentication?
We hate to use radius as hardly to deploy self-sign CA to mobile device.
Or, please advise any alternative method.
Security always stops us to use the right thing in right and not helping people.
Thanks.
7 REPLIES 7
samantha_lynn
Esteemed Contributor III
I'm sorry, I'm not sure what you're asking here. You can either link the AP to an external Radius server (using AD and LDAP if you'd like) that you already have set up. Or we can host a Radius server on an AP that uses LDAP and connects to your AD server that you have set up. If the Radius server in use has a certificate (CA), then the client devices will need the certificate as well.
bluegrass-168
Thanks Sam,
Then I don't need to setup Radius on that LDPA server and still can use the Ad account for user to connect the SSID without deployin the CA.
Is that right>?
samantha_lynn
We can set up an 802.1x SSID that links to an LDAP server that you have set up, is that what you were looking for?
